Thread: First steel diy CNC router build
No all or None is the only way really.
If you must Then Z axis is actually the most important area on the machine because it carry's the sharp bit and if that moves or flexs then doesn't matter how well built the rest is the machine will give rubbish and inaccurate parts.!!.. . . . . . . It's very common for people to under build the Z axis only to instantly regret when the chips start flying, it's also often the most upgraded part of any DIY machine.!
Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
By Wejjmeister in forum Gantry/Router Machines & BuildingReplies: 87Last Post: 03-01-2016, 12:45 AM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM
