Thread: First steel diy CNC router build
15-06-2014 #25
Like Jonathan, I thought that the Huanyang VFDs were wired to support single- or three-phase operation as that's how they are described in the manual. I just picked two terminals on mine and it works fine. But if they've changed this, or some of the current crop of Chinese VFDs don't match the usual Huanyang spec, or some are just not wired internally in accordance with the manual, then that's well worth knowing.
Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
By Wejjmeister in forum Gantry/Router Machines & BuildingReplies: 87Last Post: 03-01-2016, 12:45 AM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM
