    Yeah... I guess so. The other thing is that when I go to the address of the LPT port, its E010, which when I put it into Mach 3 as 0x010, Mach changes it to 0x10 Is this something to do with it being hex? Anyway, I'm only asking as I've just plugged it all into an old XP system (XP to the rescue again :p ) and have another odd base address (CCF8) and I'm hoping that when Mach3 has finished installing its not going to do the same. Also, what's the deal with having to have an e-stop to run code in mach? can I emulate it as being off by ticking the Active Low box? Mach 3 is installed now, so I'll report my findings. Again, thanks for all your help!
    Okay, so I've got a bit further... I think.
    I've tried all the ports/pins settings I've tried before, including the ones cropwell gave me. This time, the motors make quite a bit of noise, and I did get one to vibrate when I was using the jog tool. My parallel port says it's base address is CCF8, I tried putting this into Mach as 0xcf8 and 0xccf8 what is the correct format? Beyond this is it just a case of trying to get the right ports/pins, or have I wired the motors wrongly, or have I got the wrong step settings on the DIP switches? Thanks again.
    Ahhh this must be good news, I've noticed the axis work indicator LED's come on on the driver board (VERY faintly) when I press the corresponding axes jog buttons in mach 3... I guess this means the ports/pins settings must be right, and it is either the stepper wiring or the DIP switches I have wrong?
  1. Stepper motor tunning wiring
    By handyoodman03 in forum Stepper & Servo Motors
    Last Post: 11-01-2013, 05:49 PM
  2. Stepper Motor Wire Colour Codes
    By c cunningham in forum Stepper & Servo Motors
    Last Post: 26-01-2011, 02:13 PM
  3. CY or SY cable for stepper motor wiring?
    By Jonathan in forum General Electronics
    Last Post: 26-09-2010, 06:25 PM
  4. Stepper motor wiring
    By Buba b in forum Stepper & Servo Motors
    Last Post: 28-03-2010, 06:16 PM
  5. Stepper Motor Wiring (Screened?)
    By pequod in forum Stepper & Servo Motors
    Last Post: 03-08-2009, 10:15 AM
