Thread: Stepper wiring/colour coding
If you want to test how good your parallel port is then run the Driver test in Mach3 folder.! . . . Look for file called Driver test.!! . . . This will show better if your PP is up to speed.?
23-06-2014 #2
Just another thought about pins :- the enable pins for the axes might be better set high, even though the TB6560 has internal pull-up resistors, a floating pin could cause problems. X=4, Y-17 and Z = 5.
The Following User Says Thank You to cropwell For This Useful Post:
23-06-2014 #3
Yeah, found the driver test when I was trying to get it to work when I was trying on windows 8, Will try it on 7 when I get home, thanks for your suggestion! I will also try those enable pin settings.
Stepper motor tunning wiring
By handyoodman03 in forum Stepper & Servo MotorsReplies: 47Last Post: 11-01-2013, 05:49 PM -
Stepper Motor Wire Colour Codes
By c cunningham in forum Stepper & Servo MotorsReplies: 14Last Post: 26-01-2011, 02:13 PM -
CY or SY cable for stepper motor wiring?
By Jonathan in forum General ElectronicsReplies: 6Last Post: 26-09-2010, 06:25 PM -
Stepper motor wiring
By Buba b in forum Stepper & Servo MotorsReplies: 5Last Post: 28-03-2010, 06:16 PM -
Stepper Motor Wiring (Screened?)
By pequod in forum Stepper & Servo MotorsReplies: 19Last Post: 03-08-2009, 10:15 AM
