  1. #6
    Lives in East Lothian, United Kingdom. Last Activity: 20 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    You can spend a fortune on tools, and still not have the one needed for a job, so I wouldn't even contemplate trying to cover all eventualities!
    Alot will depend on the size of machines you have, but here's a quick list I can think of-
    Mill
    Clamp set - the usual generic kit that nearly all suppliers sell, in whatever size that fits the T-slots
    Vice - something nearing the capabilities of whatever machine you have, and something smaller if you have the funds. Large stuff you usually clamp straight to the table, but using a vise is normally easier, however mounting small stuff in a large vise can be a pain. If you have a rough idea of what you're likely to machine, use that as a guid to what vise to buy.
    End mills - For steel I usually only have 4 sizes. 12, 10, 6, and 4mm. Anything needing another size I just order when needed. I also have a some larger indexable endmills which I do use a fair bit, but that's only any good if you're machine is large/powerful enough (I picked mine up of ebay a while ago for a pretty good price)
    Boring head - pretty much essential if using a manual mill and need to bore something.
    DTI - pretty invaluable if setting up to an existing hole/truing to a surface.
    Edgefinder - as the name implies, pretty essential for setting up from a known edge
    Wobbler - handy if you need to pick up marked lines
    Lathe
    Other than the usual cutting tools, I can't think of much.
    Personally I use index tooling for 99% of stuff, with HSS saved for doing profiled stuff, however it can work out expensive.
    An indexed parting tool is a revelation for parting off, compared to using HSS.
  2. The Following User Says Thank You to m_c For This Useful Post:
  1. "Hacking" and "Modding"
  2. CNC machine "Spanish" model . Advice and opinions needed!
    By shapebusters in forum Machine Discussion
    Last Post: 12-03-2014, 06:21 AM
  3. traveling steady, turning 1/2 bar down over 10".
    By graffian in forum Metalwork Discussion
    Last Post: 08-05-2013, 07:59 PM
  4. Replies: 4
    Last Post: 28-09-2012, 12:06 PM
  5. "Racks" VS "ball screw"
