Thanks for the info guys. This is what they're coming with:
Lathe:
160mm self centering 3 jaw chuck with inside and outside jaws
200mm 4 jaw independent chuck
4 jaw self centering chuck 160mm on DL-4 backplate 200mm
4 way toolpost
Fixed and travelling steadies
Micro adjustable bedstop
Coolant system
Halogen low voltage light
Dead centres
Face plate
Digital display 2 axis for lathes/mills
Quick change toolpost set
Live centre -3mt
Centre drill set 5 piece set
9 pce set index turning tools 12mm
Drill chuck b16 3-16mm
3mt arbor b18
Milling Machine:
125mm vice
Collet chuck set er-32 3mt 3/8" whit 18 piece
20 pcs metric hss end mill/slot drill set. Tin coated. Plain shank.
W4 clamp kit 12mm
Coolant system comprising on/off switch, tank, electric parts, nozzle, magnetic feed pipe & coolant pipe 1.1m, 1/6hp 220v/50hz pump, 5 litre tank capacity.
Wide coolant tray
DRO for the milling Machine is only 2 axis as been told that as the column is round one can't be fitted. One of the first projects will be fitting one to it....
Items in addition to the above I'm getting are DTI on a magnetic base and a boring bar set. Already have centre drill bits and some tooling from the old lathe. Should suffice for now and anything else needed can just be bought as and wheen needed.
"Hacking" and "Modding"
CNC machine "Spanish" model . Advice and opinions needed!
By shapebusters in forum Machine DiscussionReplies: 17Last Post: 12-03-2014, 06:21 AM -
traveling steady, turning 1/2 bar down over 10".
By graffian in forum Metalwork DiscussionReplies: 3Last Post: 08-05-2013, 07:59 PM -
Interesting Article "Makers unite - the revolution will be home-made"
By Fivetide in forum General DiscussionReplies: 4Last Post: 28-09-2012, 12:06 PM -
"Racks" VS "ball screw"
By C.AlveSilva in forum Linear & Rotary MotionReplies: 1Last Post: 17-04-2012, 11:53 PM
