    Lives in East Lothian, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    How are the swithces being daisychained together?
    If it's just a case of the output from one being tied to the +/- of the next, then I wouldn't of thought it would be that good a solution as I know some prox switches can take a noticeable amount of time to power down and fully kill their output.
    I would of thought a better option would be to daisychain the outputs through something like an optocoupler bank.
    I do it just same as Goblin explained for limits and it works fine even with cheap prox swiches. Even with one switch at each end which I rarely do as I like to keep wiring to a minimum they work fine.
    For Home switches then I always wire them in parallel.
  1. Proximity limit switch problems
    By davrich in forum General Electronics
    Last Post: 12-03-2018, 01:58 PM
  2. Proximity Wiring Problem
    By Bruce in forum General Electronics
    Last Post: 13-01-2014, 07:21 PM
  3. Proximity Switches
    By kingcreaky in forum General Electronics
    Last Post: 23-10-2013, 01:30 PM
  4. Proximity sensor help required
    By plasticsales in forum General Electronics
    Last Post: 21-08-2013, 07:02 PM
  5. Proximity Sensors as Limit Switches ?
    Last Post: 03-10-2009, 07:04 PM
