Thread: Aluminium cutting
21-04-2014 #1
I wonder if someone could check my setting for cutting aluminium as I keep breaking end mills. The last time I had this settings. The aluminium is 6082 T651 18mm thick I am just using this to test. I'm trying to pocket out a 25mm diameter hole only 6mm deep and I'm only getting to half way round the second pass.
The bit is a 1/8th single flute carbide bit, the depth of pass is 1mm RPM is 15000, chip load I have as 0.003 which I workout as 1142mm per minute feed rate plunge rate I have as 126mm per minute, the coolant I am using it duck oil its like WD40 but does not evaporate like WD40 and is a better lubricator.
Recap. Aluminium is 6082
Bit is 1/8th carbide single flute.
feed speed is 1142 mm/per/minute
plunge rate is 126 mm/per/minute
spindle speed is 15000 rpm
depth per cut is 1 mm
step over is 30% 0.952 mm
chip load is 0.003
There must be something in there where I have picked up wrong for working out feed and speed.
This is how I worked out my feed rate.
Feed Rate = RPM x number of flutes x Chip load.
Which gave me 45 I/P/M then to change to metric I divide that by 39.374 which gave me 1.142 metre which is 1142 mm. or multiply 45" by 25.4 which is 1143mm
Or is this all wrong.
Dry Aluminium Cutting Problem
By Tenson in forum Tool & Tooling TechnologyReplies: 22Last Post: 29-08-2016, 11:41 PM -
Cutting Aluminium With A Cheapo 3020 CNC
By Pointy in forum Metalwork DiscussionReplies: 5Last Post: 05-05-2014, 09:59 AM -
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
RFQ: RFQ: Need some thin aluminium cutting
By stewpid22 in forum Projects, Jobs & RequestsReplies: 0Last Post: 21-09-2012, 01:11 PM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM
