Page 6 of 6 FirstFirst ... 456
  1. #51
    some good advices here, thanks for posting
  2. #52
    Dean, did you ever test the bits?
  3. If anybody needs speeds & feeds for Aluminium cutting I will be more than happy to help. Just let me know!
  4. #54
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 6 Hours Ago Has a total post count of 1,653. Received thanks 115 times, giving thanks to others 71 times.
    Also keen to know .....
  5. #55
    I have a few of these - http://www.ebay.co.uk/itm/371406148992 - they are cheap and not advertised as anything special. I bought them initially for plastics, but then tried them on Aluminium and found they were great.
    Last week I had some small parts to make in 304 Stainless from 12mm rolled stock and thought "What the heck!", loaded up a single flute (I did re-grind the tip to what I felt should be a slightly more robust form) and it proceeded to carve out my parts seamlessly.
    I used air for cooling and chip clearance plus mist lubrication,
    - Nick
  6. The Following User Says Thank You to magicniner For This Useful Post:
  7. #56
    Chaz's Avatar
    - Nick
    Thanks. Im still hurting from breaking two fairly expensive roughing end mills. Mostly my own fault and not having enough spindle power. Having a some other options to mess around with will be good. Ill order a few of these and try them.
    I am happy with the APT supplied end mills. I'm getting great finishes with the 10mm 3 flute endmill from them but they arent cheap. The roughing mills are expensive too (£35ish for 10mm) but they work well (if you dont break them).
  1. Dry Aluminium Cutting Problem
    By Tenson in forum Tool & Tooling Technology
    Last Post: 29-08-2016, 11:41 PM
  2. Cutting Aluminium With A Cheapo 3020 CNC
    By Pointy in forum Metalwork Discussion
    Last Post: 05-05-2014, 09:59 AM
  3. aluminium profile for cutting bed of router
  4. RFQ: RFQ: Need some thin aluminium cutting
    By stewpid22 in forum Projects, Jobs & Requests
    Last Post: 21-09-2012, 01:11 PM
  5. WANTED: CNC Mill/Router for Cutting Aluminium
    By kylelnsn in forum Items Wanted
    Last Post: 09-08-2012, 09:54 PM
