Thread: Aluminium cutting
I have tried a slower feed rate but it blunt the end mill to a point it was not cutting but I cant remember the setting since then I have started to keep a note of what I have been trying. If I took the spindle speed down to 10000 rpm then the feed rate would be 30inch a minute or 762mm per minute, at a chip load of 0.003 but if my feed rate is to fast at 15000 rpm at 1142mm per minute should it not be the case that at 10000 rpm at a feed rate of 762mm per minute still be wrong. is there something wrong with the calculation that I have found or is it the chip load that is wrong for a 1/8th single flute end mill. also how slow can you take a water cooled 0.8kw spindle before it would stall when cutting.
Dry Aluminium Cutting Problem
By Tenson in forum Tool & Tooling TechnologyReplies: 22Last Post: 29-08-2016, 11:41 PM -
Cutting Aluminium With A Cheapo 3020 CNC
By Pointy in forum Metalwork DiscussionReplies: 5Last Post: 05-05-2014, 09:59 AM -
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
RFQ: RFQ: Need some thin aluminium cutting
By stewpid22 in forum Projects, Jobs & RequestsReplies: 0Last Post: 21-09-2012, 01:11 PM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM
