    Well that didn't work out well, cutting 6082 aluminium. The settings were. 12000rpm. Feed rate of 325mm per minute. Plunge rate of 254mm per minute, with a depth of cut 1mm. I used a 3.175mm single flute carbide bit, but as soon as the bit cut in to the side of the aluminium the bit broke, so I tried a cut depth 0.5 mm. The bit did cut through the aluminium of 60mm wide but by the time it was at the end there was a poor shaving curl and when I got down to 5.5mm deep it broke that end mill as well. I did use cutting oil and it was a wash with it, also there was no smoke coming from the bit so it was not getting hot. So what do I do now should I reduce the depth of cut a little more or speed up feed rate. Or is it that I am using to small a size end mill?
    Hi Bush flyer,
    I recently cut some elongated slots with a 3mm carbide bit without any problems. I don't use the 3mm cutter much (tend to use 6mm) so haven't experimented but the following settings worked OK:
    DOC 0.3mm
    rpm 12,000
    300mm/min feedrate
    30mm/min plunge rate
    The 4 slots were 5mm wide, 15mm long, and 10mm deep (other side is pocketed 10mm). See photos below.
ID:	12324 Click image for larger version.
    (I was actually surfacing the whole part in this photo - hence the 6mm cutter in the collet, not 3mm, but you can see the slots I was refering to)
    I flooded the holes with duck oil as soon as cutting started. There was no smoke, no screeching, just a soup of very small chippings swirling around in the pocket as the cutter did it's job.
  3. The Following User Says Thank You to routercnc For This Useful Post:
    Hi Bush flyer,
    What's the cutter details ? e.g. single flute, up spiral
    Edit: This might seem a daft question but to me the thread is going round in a circle until Bush Flyer uses a cutter of the same type and most importantly, brand, that others are using when they suggest cutting parameters. The difference between a good cutter and a bad one is chalk and cheese.
  1. Dry Aluminium Cutting Problem
    By Tenson in forum Tool & Tooling Technology
    Last Post: 29-08-2016, 11:41 PM
  2. Cutting Aluminium With A Cheapo 3020 CNC
    By Pointy in forum Metalwork Discussion
    Last Post: 05-05-2014, 09:59 AM
  3. aluminium profile for cutting bed of router
  4. RFQ: RFQ: Need some thin aluminium cutting
    By stewpid22 in forum Projects, Jobs & Requests
    Last Post: 21-09-2012, 01:11 PM
  5. WANTED: CNC Mill/Router for Cutting Aluminium
    By kylelnsn in forum Items Wanted
    Last Post: 09-08-2012, 09:54 PM
