  1. #10
    I find that Fz=D/100 usually too much. Especially about aluminum. Not talking about roughing bits. Tools 0-2mm is one thing, 3mm is another thing, 4-6 mm another, and so on.
    I have Gwizard trial installed but some how this program doesn't engage me, may be the price and subscription put me off.
    Just found the free online FSWizard and actually the data it gives is quite near the manufacturer data and very very near at my actual cutting data. So i am quite convinced and maybe even will buy the payed version
    The bits i use are mainly Kyocera, razor sharp and polished. Now looking at their data below, some conclusions about how things develop with sizing and type of operation can be drawn. This is quite more realistic than others i have seen.
    Vc - cutting speed
    f - chip load or feed per tooth
    Fr- feed rate mm/min
    D- diameter of carbide bit
    U- nimber of teeth on cutter
    p=3.14
    Ae - side removal
    Ap - face removal
    1.
    determine spindle speed rpm/min depending an operation/roughing, slotting, finishing/
    RPM=(Vc*1000)/(p*D)
    2.
    Calculate feed rate mm/min:
    Fr=f*U*RPM
Name:	mm milling 1a.PNG
ID:	13465   Click image for larger version.
Name:	mm milling 2a.PNG
ID:	13466   Click image for larger version.
Name:	mm milling 3.PNG
  1. Dry Aluminium Cutting Problem
    By Tenson in forum Tool & Tooling Technology
    Last Post: 29-08-2016, 11:41 PM
  2. Cutting Aluminium With A Cheapo 3020 CNC
    By Pointy in forum Metalwork Discussion
    Last Post: 05-05-2014, 09:59 AM
  3. aluminium profile for cutting bed of router
  4. RFQ: RFQ: Need some thin aluminium cutting
    By stewpid22 in forum Projects, Jobs & Requests
    Last Post: 21-09-2012, 01:11 PM
  5. WANTED: CNC Mill/Router for Cutting Aluminium
    By kylelnsn in forum Items Wanted
    Last Post: 09-08-2012, 09:54 PM
