Thread: Aluminium cutting
some good advices here, thanks for posting
17-04-2015 #2
23-04-2015 #3
If anybody needs speeds & feeds for Aluminium cutting I will be more than happy to help. Just let me know!
12-05-2016 #4
13-05-2016 #5
I have a few of these - http://www.ebay.co.uk/itm/371406148992 - they are cheap and not advertised as anything special. I bought them initially for plastics, but then tried them on Aluminium and found they were great.
Last week I had some small parts to make in 304 Stainless from 12mm rolled stock and thought "What the heck!", loaded up a single flute (I did re-grind the tip to what I felt should be a slightly more robust form) and it proceeded to carve out my parts seamlessly.
I used air for cooling and chip clearance plus mist lubrication,
The Following User Says Thank You to magicniner For This Useful Post:
13-05-2016 #6
Thanks. Im still hurting from breaking two fairly expensive roughing end mills. Mostly my own fault and not having enough spindle power. Having a some other options to mess around with will be good. Ill order a few of these and try them.
I am happy with the APT supplied end mills. I'm getting great finishes with the 10mm 3 flute endmill from them but they arent cheap. The roughing mills are expensive too (£35ish for 10mm) but they work well (if you dont break them).
Dry Aluminium Cutting Problem
By Tenson in forum Tool & Tooling TechnologyReplies: 22Last Post: 29-08-2016, 11:41 PM -
Cutting Aluminium With A Cheapo 3020 CNC
By Pointy in forum Metalwork DiscussionReplies: 5Last Post: 05-05-2014, 09:59 AM -
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
RFQ: RFQ: Need some thin aluminium cutting
By stewpid22 in forum Projects, Jobs & RequestsReplies: 0Last Post: 21-09-2012, 01:11 PM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM
