28-04-2014 #61
Yes this is an option and will be my backup if nothing full fulls my perfect needs.
Irving I'm following your design and with some googling I've found it uses a Hex Schmitt trigger, Flip flop and down counter so I'm learning already . .
. . . . Now I just need to get my head around what they are and how they play together.
While googling the codes have been showing up with letters on the ends like "BE" or "BCM" what do they indicate.?
Should I start to play with this now and get these bits to play with or will there be more versions so hold off.?
29-04-2014 #62
Hi Dean,
You wanted a learning experience so I deliberately left some info off the diagram. :)
These chips come in various package formats, the suffix identifies which so decide how you're going to build it and get the appropriate version. If you're breadboard it you need the PDIP package.
I don't foresee any major changes and these chips are only 30p or so so get them. Maybe even a couple of each just in case :)
I do need to consider Jonathan's valid suggestion re direction so there will be a v0.2 shortly.Last edited by irving2008; 29-04-2014 at 06:38 AM.
29-04-2014 #63
29-04-2014 #64
Here's another idea.
I used to work on plant where Selsyn Motors were used for synchronisation purposes and remote indication. It occurred to me that stepper motors were very similar so a quick search found this;
Fun with Stepper Motors - Synchronous Operation without Power - YouTube
No external electrical power required just a crank handle on a spare stepper motor.Last edited by EddyCurrent; 29-04-2014 at 10:26 AM.
29-04-2014 #65
29-04-2014 #66
Good man I like a challenge. . Lol
Yes BB at first then will probably make a better job with a board.
Ok there's no rush so I'll wait until everything settles down then just buy a load of bits at same time and I'm sure there'll be plenty of Magic smoke in the air so I'll get spares. . Lol
Not being savy with these electronictrickery gismo's then it's probably technical chip stuff why it's a problem but Won't the drive take care of the Direction just with 5V on the Dir pin.?
29-04-2014 #67
Post #48-49: Looks like that was meant as a serious comment - sorry I didn't realise.
If you apply 5V across the DIR pins the motor will spin one way, apply 0V (or leave disconnected) and it will spin the other way. You could could do that simply with a switch if you're happy for the machine to go in the direction set by the switch, not follow the direction in which the MPG is spun.Last edited by Jonathan; 29-04-2014 at 07:01 PM. Reason: comma splice
29-04-2014 #68
Obviously I know this and thats what I've been doing just with MPG. This is what I've been saying I just want it simple so flicking switch is fine and spinning mpg just for movement. Just I need faster than the single pulse the MPG spins at but still want the abilty to single step when needed.
555 + MPG would work and would probably be simplist but I don't mind playing and want to learn something in the process and so long as Irving or some other kind sole doesn't mind giving directions then I'll wait and see all the options.!
29-04-2014 #69
if you're ok with a switch for Dir then there won't be a v2 at the mo.
Suggest, if not done already, you download & print off datasheets for chips and get a handle on what each does.
30-04-2014 #70
Mach Turn
By Kai in forum CAD & CAM SoftwareReplies: 5Last Post: 02-08-2016, 02:40 PM -
MPG or Hand Wheel Pulse Encoder where to buy in UK?
By suesi34e in forum Marketplace DiscussionReplies: 5Last Post: 02-01-2014, 04:41 PM -
clunks / missing steps - DM856 and single pulse operation
By dsc in forum Motor Drivers & ControllersReplies: 37Last Post: 09-12-2013, 02:22 PM -
Pulse rate or dip switch settings
By Jopo in forum Stepper & Servo MotorsReplies: 0Last Post: 29-04-2013, 08:08 AM -
LED not turn on
By Awel in forum Motor Drivers & ControllersReplies: 1Last Post: 06-12-2011, 06:59 AM
