23-04-2014 #11
I know you said ideally not using an Arduino, but if you want it simple they're hard to beat as the principle of Arduino's seems to make the electronics and coding as simple as possible. The Arduino Uno has 5V outputs, so you can connect it directly to the stepper driver - no other components required.
The timing diagram Eddy's highlighted would be easy to follow with the Arduino, but for this application we don't need to worry about it too much - just set the step pulse width to at least 5us and it'll be fine.
Just to be clear, do you just want to control one motor at a time? For instance just use a potentiometer to set the speed and the circuit outputs the pulse train to get that speed?
(By all meant do it using one of the other ways suggested in this thread - they all look fine to me.)
Mach Turn
By Kai in forum CAD & CAM SoftwareReplies: 5Last Post: 02-08-2016, 02:40 PM -
MPG or Hand Wheel Pulse Encoder where to buy in UK?
By suesi34e in forum Marketplace DiscussionReplies: 5Last Post: 02-01-2014, 04:41 PM -
clunks / missing steps - DM856 and single pulse operation
By dsc in forum Motor Drivers & ControllersReplies: 37Last Post: 09-12-2013, 02:22 PM -
Pulse rate or dip switch settings
By Jopo in forum Stepper & Servo MotorsReplies: 0Last Post: 29-04-2013, 08:08 AM -
LED not turn on
By Awel in forum Motor Drivers & ControllersReplies: 1Last Post: 06-12-2011, 06:59 AM
