23-04-2014 #2
I've used hand held routers with 26000 rpm and single flute TCT for 2mm and that's cut fine. But I would say 300 rpm would be to slow. This might help you, scroll down about half way down the page. You'll see this
" Computerised trimming is a fully automatic milling process. It is extremely accurate and operates horizontally as well as vertically. The use of a vacuum-operated jig avoids vibration of the part ensuring a smooth cut. Standard high speed, two sided cutting routers with tungsten carbide tips are recommended, with a cutting speed of approximately 250 m/min at 25.000/30.000 RPM at a sheet thickness of 4 mm."
http://www.theplasticshop.co.uk/plas...sing_guide.pdf
Hope this helps. Mike
Emco pc mill 55 upgrade
By Craiggillzzr1400zx10r in forum Emco Milling MachinesReplies: 30Last Post: 31-08-2016, 03:13 AM -
CONVERSION: Emco Mentor Mill conversion
By Ross77 in forum Conversion Build LogsReplies: 63Last Post: 13-01-2016, 06:40 PM -
FOR SALE: Emco mill 50 cnc mill like Denford Triac
By gavztheouch in forum Items For SaleReplies: 0Last Post: 18-05-2014, 10:19 AM -
Emco mill 50 Y axis travel?
By gavztheouch in forum Emco Milling MachinesReplies: 0Last Post: 01-03-2014, 11:10 AM -
WANTED: denford nova/star mill - emco f1/ pc50 - boxford vmc or similar wanted
By jonnydeen in forum Items WantedReplies: 2Last Post: 04-06-2012, 12:31 PM
