23-04-2014 #1
I have a emco mill 50 will a 3000rpm max spindle. I need to use a 2mm cutter to mill/route lexan material. I have a feeling the spindles going to be to slow with the small cutter. Has anyone tried milling lexan? Is my spindle too slow?
CheersCNC routing and prototyping services www.cncscotland.co.uk
ADD ME ON FACEBOOKS
23-04-2014 #2
I've used hand held routers with 26000 rpm and single flute TCT for 2mm and that's cut fine. But I would say 300 rpm would be to slow. This might help you, scroll down about half way down the page. You'll see this
" Computerised trimming is a fully automatic milling process. It is extremely accurate and operates horizontally as well as vertically. The use of a vacuum-operated jig avoids vibration of the part ensuring a smooth cut. Standard high speed, two sided cutting routers with tungsten carbide tips are recommended, with a cutting speed of approximately 250 m/min at 25.000/30.000 RPM at a sheet thickness of 4 mm."
http://www.theplasticshop.co.uk/plas...sing_guide.pdf
Hope this helps. Mike
23-04-2014 #3
You may also find that a cutting fluid made of approx 50-50 dish detergent and water will help immensely
dave
25-04-2014 #4
Thanks guys sounds like my spindle may be too slow. Might try and get some lexan to make some test cuts before commiting to the job.
ADD ME ON FACEBOOKS
Emco pc mill 55 upgrade
By Craiggillzzr1400zx10r in forum Emco Milling MachinesReplies: 30Last Post: 31-08-2016, 03:13 AM -
CONVERSION: Emco Mentor Mill conversion
By Ross77 in forum Conversion Build LogsReplies: 63Last Post: 13-01-2016, 06:40 PM -
FOR SALE: Emco mill 50 cnc mill like Denford Triac
By gavztheouch in forum Items For SaleReplies: 0Last Post: 18-05-2014, 10:19 AM -
Emco mill 50 Y axis travel?
By gavztheouch in forum Emco Milling MachinesReplies: 0Last Post: 01-03-2014, 11:10 AM -
WANTED: denford nova/star mill - emco f1/ pc50 - boxford vmc or similar wanted
By jonnydeen in forum Items WantedReplies: 2Last Post: 04-06-2012, 12:31 PM
