Thread: Hello from Iran
    Hi everybody
    I want to make laser cutting router to cut textiles (stacked on up to 120 mm in height) . I welcome any proposal and suggestions.
  3. The Following User Says Thank You to jcb121 For This Useful Post:
    Hi all
    Finally I made my first CNC skeleton model in Autodesk Inventor.
    - The structure is composed of square hollow sections of size 100x100x6 mm
    - Structure weights about 555 kg
    - Dimensions: 2500x1500x500 mm (LxWxH)
    I analyzed it to find its natural frequencies. I found the following data:
    - 1st Mode: modal frequency: 60.69 Hz - maximum displacement: 151.2 mm (too high! I think if I use ANSYS more precise results could be found)
    - 2nd Mode: modal frequency: 66.76 - maximum displacement: 151.2 mm.
    I don't know any thing about acceptable ranges for frequencies and their corresponding displacements in CNC machines.
    Here you can see the model and modal analysis results:
Name:	Chassis Skelton.png
ID:	12378Click image for larger version.
Name:	Chassis Skelton1.png
    Thanks for any suggestions
    Jamshid
  5. #4
    I analyzed the structure in ANSYS. Results are better and more hopeful but the question remains: What is the preferred (acceptable) range for frequencies and relevant deformation in CNC machines like the one that i am going to build? Any suggestions? Thanks.
ID:	12382Click image for larger version.
ID:	12383Click image for larger version.
ID:	12384Click image for larger version.
ID:	12385Click image for larger version.
ID:	12386Click image for larger version.
ID:	12387Click image for larger version.
  6. #5
    Have you seen evidence that a laser will cut through that thickness of material. I would imagine the power needed to slice through that much fabric would charr the edges and set the material on fire. I don't know what your budget is but if you really need a laser to do this you are not talking about hobby prices think 10's of thousands. I think a knife or recipricating saw blade is what is commonly used for thick stacks. How detailed are the cutting patterns you what to cut?
    CNC routing and prototyping services www.cncscotland.co.uk
    ADD ME ON FACEBOOKS
  7. The Following User Says Thank You to gavztheouch For This Useful Post:
  1. NEW MEMBER: hello from Iran
    By cisco in forum New Member Introductions
    Last Post: 08-01-2011, 01:04 AM
