27-04-2014 #6
Hi m_c
Many thanks for your valuable help once again. The info you have provided shouldgive me a good start on what to think about. Once I get time later I hope toget the back of the machine and see if I can identify the boards and see if Ican make some sense of things.
Some things I have been thinking about for a long time is that the router is a single speed so perhaps that may make things simpler. There is also an on off switch on the router so I am not sure if it could be turned on and off with M3 / M5 or just manually.
Anyhow thank you again for your advice which will be of help you have mentioned so much I did not know about.
All the best
suesiLast edited by suesi34e; 27-04-2014 at 05:42 PM.
FOR SALE: Marchant dice cnc router mill compatiable with mach 3
By gavztheouch in forum Items For SaleReplies: 7Last Post: 23-03-2021, 12:59 PM -
Denford digiplan 300 drivers, i cant get them to run on mach 3
By scnc in forum Motor Drivers & ControllersReplies: 5Last Post: 30-04-2014, 09:56 PM -
Emco Compact 5 Conversion
By Pete92 in forum Emco LathesReplies: 7Last Post: 01-10-2013, 11:31 PM -
convert traditional machine or build router?
By Henrik in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 22-03-2013, 08:49 AM -
mach 3/ router help wanted: ayrshire
By advertisigndirect in forum Artsoft Mach (3 & 4)Replies: 0Last Post: 05-02-2010, 11:56 PM
