  1. Hey Slim,
    Would these be of any use to you: 20pc Drum Sanding Kit Fit Drill
    I use these in my drill press all the time and they work quite well, I was thinking you could bore a hole in your current ali bar to fit the shank on these, this would then get the reach you may need?
    .Me
    Hey Lee, I do use them when I am not going deep into the bamboo pole but they don't last very long either. Fatfreddies idea of using microplane might be the way forward but after reading some reviews I am not too sure about those either as they are expensive and I am not too sure about the quality too. I wonder how they actually make the filing surface on the tools used for filing really. It would be the best option for my tool. I will keep pondering I guess. Cheers
    you could knurl the ali bar, thou it might be more lasting if you did it to a steel bar and used that like a file.
    You could maybe use a grade of steel that's easy to harden, machine it to just under the diameter you need on a lathe, knurl it, then harden it.
    That's pretty close to a file. You could mill/grind some flutes so the swarf has somewhere to go.
    Thanks Jonathan and Tornado, I think I have my answer. Will get a steel bar and knurl it. Do the knurling tools come with various pitches so that I can knurl it in such a way that the protrusions are long a sharpish? Thanks
    i think my kit i have has 2 course, 2 medium and 2 fine kurl wheels.
    the best one to get it the clamp type, that clamps on top and bottom of the workpiece.
    the single wheels ones have to push against the workpiece and can stress the lathe bearings
    Can you recommend a course wheels one please? Also can the top and bottom wheels reduce the wobble in my round bar too? Not sure why a think piece of ali is wobbling when it turns?
  1. Small workbench drum sanders ?
    By Fivetide in forum Marketplace Discussion
    Last Post: 26-11-2013, 12:53 PM
  2. Replies: 4
    Last Post: 26-04-2013, 08:37 AM
  3. How would you make these, or something near enough...
    Last Post: 22-09-2012, 09:36 PM
  4. Can somebody make me one of these?
    By Imtryin in forum General Discussion
    Last Post: 28-06-2011, 06:53 PM
  5. The 'ultimate rev counter' thread...
    By irving2008 in forum Electronic Project Building
    Last Post: 15-08-2010, 10:18 AM
