    Ger21's Avatar
    Lives in Detroit, United States. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 651. Received thanks 90 times, giving thanks to others 0 times. Referred 1 members to the community.
    that said, it would be good to see anyone's idea of what percentage of your budget you' should allocate to which part of the machine... e.g. 15% on base structure, 35% xyz hard wear 50% on power, control, motors etc....
    So you get the best out for your buck..
    any takers?
    I've never seen anyone try to break it down that way. Probably because it doesn't work. You can't really cut corners anywhere without sacrificing the quality of the machine.
    Good linear guides are the foundation of a good machine. Cutting corners there directly impacts the quality of the machine.
    Good linear guides require a solid, rigid frame. The straightness and rigidity of the linear guides is dependent on the mounting surfaces, so you can't cut corners there.
    Good motors and bad motors are all about the same price. There aren't really good and bad motors, but rather correct and incorrect for your application.
    You can save a bit of money on drives. However, most people that cut corners on drives tend to upgrade to the better drives to improve performance, and end up spending more than if they had purchased the good drives in the first place.
    The cheapest way to get a good machine is to spend more money. Any places you try to save money will usually result in spending more money later to replace the cheap components. Or you live with an inferior machine that still cost 80% of what a good machine would have cost.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  2. The Following 2 Users Say Thank You to Ger21 For This Useful Post:
  3. #2
    Missed this last night but Excellent reply that Gerry best way I've seen it said yet.!! . .
  1. Geckodrive - The G215 Step and Direction or VCO
    By Lee Roberts in forum Motor Drivers & Controllers
    Last Post: 31-03-2012, 10:42 PM
  2. newbie desperate for a shove in the right direction
    By swinds in forum Machine Discussion
    Last Post: 22-06-2011, 11:13 PM
  3. NEW MEMBER: New Member, saying Hello and hoping for direction
    By GMNOCNC in forum New Member Introductions
    Last Post: 07-03-2011, 11:50 AM
  4. sudden change of direction
    By Dan Brown in forum Motor Drivers & Controllers
    Last Post: 06-03-2010, 11:30 AM
  5. Reversing motor direction in Mach3
    By bruce_miranda in forum Artsoft Mach (3 & 4)
    Last Post: 16-11-2008, 06:54 PM
