    Hi, folks. I have hot pots! After maybe towards an hour, my stepper motors overheat. They can get to 80+ degrees C! (useful to light my cigarettes from..;)
    I'm using that blasted TB6560 blue Chinese board (with NEMA 17's on a Zen 6x6 router), and was wondering if setting the DIP switches to a lower amperage might help? I'm running it at 15v, and it sucks (the board) 1.5A max on a typical cut.
    On startup, all motors run fine, with no untoward noises.
    TIA,
    Lives in Plymouth, United Kingdom. Last Activity: 3 Weeks Ago Has a total post count of 1,749. Received thanks 299 times, giving thanks to others 11 times.
    I worried about the steppers on my machine which probably reach that kind of temp. When I googled it a bit, the general view was that steppers do run hot, and I seem to remember figures of over 100C being normal. I don't worry if it's too hot to touch as long as it isn't hot enough to boil water (i.e. fizz when you touch it with a wet fingertip). I did turn down the max current a bit, which helped.
    I have found a PRC i/r thermometer very useful for this, too - it probably only cost me a fiver from fleabay... Cheers for your response.
  5. #4
    It takes most people by surprise but
    it is normal for stepper motors run too hot to the touch
    different manufacturers give the maximum temperature as 70 to 80 C
    RS Pro High Torque Hybrid Stepper Motor Stock No: 535-0401 as an example
Name:	RS Pro  H i g h   T o r q u e   H y b r i d   Stepper Motor.pdf
    John
  6. The Following User Says Thank You to john swift For This Useful Post:
  1. Overheating stepper motors
    By Skysurfer in forum Motor Drivers & Controllers
    Last Post: 06-05-2014, 12:40 PM
  2. stepper motors not being driven
    By sprint in forum Machine Control Software
    Last Post: 12-02-2013, 03:42 AM
  3. Help with Stepper Motors
    By Scott in forum Stepper & Servo Motors
    Last Post: 04-04-2010, 02:35 PM
  4. rs stepper motors
    By chaz@2b in forum Stepper & Servo Motors
    Last Post: 06-08-2009, 11:05 PM
