08-05-2014 #11
Thanks guys, I have tried various things and have now got it to zero return. I have had to change the following, X to 13 Y to 10 and Z to 12 and active low ticked on all of them. As I said, home ref works to switches and the only problem now is the jog wheel in X operates in the wrong direction, this because I needed to change motor output Dir low active on the X axis to a tick in order for it to ref home in the right direction.
08-05-2014 #12
10-05-2014 #13
Hi Jazz
Thank you for that, but unfortunately that did not work.
10-05-2014 #14
Think you best explain again the problem because changing the keys would change the direction unless you didn't apply the changes by clicking ok.?
The other thing to try and really what you should have done instead of changing the X motor active state is to use the Reversed option in the Homing/limits. So set the X motor state back to previous state and try this and between this and changing the keys you'll get moving in the right directions.
12-05-2014 #15
Hey Jazz, all sorted now, many many thanks for your help. Its been a good learning curb for me and helped me to understand the configuration of the machine.
Regards
Sparky
13-11-2014 #16
Hi Sparky,
I think I've got the same controller as you (labelled CNC SuperBox on the front).
I've struggled to find any documentation for it online and can't work out the pinout for Mach3 to control it.
Have you a manual you can send or a list of your pin mapping?
Many thanks,
Sam
13-11-2014 #17
Anything here like it ?
http://www.marchantdice.com/forum/vi...477a4d12f6356cSpelling mistakes are not intentional, I only seem to see them some time after I've posted
13-11-2014 #18
Hi EddyCurrent, yes!
Thank you, it's listed as an SBOX which is why I think Google was struggling to bring up many results when I've been looking for Super Box (as per the front panel).
I'll have a read through that and should be able to figure it out now, thanks for your help.
Huanyang VFD control plugin for Mach3, USB RS-485
By JayPunchbuggy in forum Spindles & Drive MotorsReplies: 19Last Post: 15-05-2013, 08:00 PM -
2 motors on X how do I setup Mach3
By phill05 in forum Artsoft Mach (3 & 4)Replies: 17Last Post: 04-02-2013, 09:33 PM -
Mach3 / Offsets / Tool setup etc
By dudz in forum Artsoft Mach (3 & 4)Replies: 0Last Post: 20-11-2012, 03:51 PM -
New CNC Router Setup Tool For Use With Mach3
By CambiumMachines in forum Manufacturer NewsReplies: 3Last Post: 08-06-2012, 04:14 AM -
HID interface for remote control of Mach3
By Smiler in forum Electronic Project BuildingReplies: 0Last Post: 10-05-2009, 12:59 PM
