Thread: Canola oil as a coolant ?
+1
I use Castrol Cooledge BI, mainly because I got most of a 20L container cheaply. I've not needed to use it on brass, but it says it's suitable in the datasheet.Last edited by Jonathan; 11-05-2014 at 11:36 PM.
10-09-2014 #2
rapeseed oil works well if applied directly to the workpiece and removed afterwards. I've used it a few times for cutting stainless steel.
But: I would never put it into a machines coolant system. Fist: it is quite thick - but most important: it will rot and become a total mess after a few months.
Christian2D / 3D CAM Software and CNC controller: http://www.estlcam.com
10-09-2014 #3
Yes - I found that out the hard way, fortunately I drained it out before it set.
10-09-2014 #4
It's not the oil I've fancied,
Because the bas$*rd goes all rancid.
(you didn't know I was a poet !
Coolant, I am not sure which one to go with.
By suesi34e in forum Swarf & Chip ManagementReplies: 23Last Post: 17-10-2015, 07:13 PM -
My Coolant System
By Tenson in forum Swarf & Chip ManagementReplies: 6Last Post: 08-04-2013, 01:59 PM -
coolant
By luke11cnc in forum Machine DiscussionReplies: 4Last Post: 11-02-2012, 01:17 PM -
What coolant to use??
By don_jarr in forum General DiscussionReplies: 13Last Post: 05-11-2011, 03:12 PM -
eBay: Castrol Cooledge Cutting Coolant Suds
By Lee Roberts in forum Items On eBay UKReplies: 3Last Post: 09-08-2009, 09:42 PM
