    hello
    can you post them too???
    wanted no circular rail
    thk style bolt to t-slot rail wanted
    can be anything up to 32mm in width across the two dooberies
    4 bits 600 long.8 bearings
    bearings can be two peice whatsnames
    also wanted long closed toothed belt,
    3 motors and dives and psu
    4 toothed pulleys
    4 flanged idler pulleys
    prefer a 20mm ish sized belt
    Lives in Marple Stockport, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by nobby View Post
    hello
    It would be helpful if you stated the size etc. ..Clive
    Come on your Man your not being charged by the letter give more info.! Using the thread title ONLY to ask a question smacks of can't be arsed and I for one will take the same attitude and think bollocks if you can't be botherd to tell me what you want I'm not asking.!!
  5. #4
    hello
    4 toothed pulleys
    So you just want a bag of assorted bits? Posted to where ever will do. ..Clive
  6. #5
    Come on Clive can't you see he wont's a Bag of "THINGY's". . for the "Dooberies" so he can fasten it to his "Whatsnames". .!!!
  7. #6
    ok I have changed my mind and want
    2 2525mm long 25mm wide 5mm pitch closed loop belts
    8 pulleys to match the above, and what ever bore they are I want
    4 motors to suit nema 23 small less than 3.1 the small ones not 115mm 425kn or 76mm long 3.1nm's
    also want 4 idler pulleys
    also want 4 bits of thk rail at about 2 foot long and the bearings for 10mm slots with the t-nuts and bolts.
    also want a pilot arc machine torch not a p-80 the smaller one for about 50 shockers.
  8. #7
    ok
    two 2525mm 25mm wide 5mm pitched closed loop belts
    eight pulleys to match with the edged rim
    four nema 23's dual shafts not 76mm long 3.1nm the smaller ones
    for 25mm idler bearings
    four lengths of thk rail I do not care what width as long as the bearings are there and all four are at least 600mm long
  9. #8
    Nobby I am sorry for you as I don't understand your requests and possibly others will not either.
    How can you ask for a belt 2525mm long and pulleys to match without specifying the diameter and or the number of teeth and bore of them etc.
    I would suggest that you sit down and think about what you want and start by putting a sketch up of what you are trying to achieve this way others (brighter than me) will understand what it is you actually want.
    Please take this criticism in the spirit in which it is intended. ..Clive
  10. #9
    simple H-bot
    quad nema 23 - may go 17
    45mm box t slot 600mm square - I have that
    20mm thk rails need 4 bits 500mm long
    want a 2525mm long belt 25mm wide 5mm pitched
    need the pulleys to be about 16mm in diameter???
    the pulleys I have seen state pilot bore? what actual size is that?
    I reckon I only need a 15mm wide belt with nema 17's 5mm shafts, are the pulleys 5mm pilot bored
    do they come with the grub screws
    to be
  1. FOR SALE: 16mm round rail, bearings and clamps - 300mm long
    By Tenson in forum Items For Sale
    Last Post: 25-01-2014, 12:43 AM
  2. Machine bed T bolt
    By Colin Barron in forum Gantry/Router Machines & Building
    Last Post: 02-10-2010, 11:20 PM
  3. FOR SALE: Round linear rail and bearings
    By routercnc in forum Items For Sale
    Last Post: 19-08-2010, 05:17 PM
  4. WANTED: Where can I get some 8 - 10mm linear bearings - rail
    By alanb in forum Items Wanted
    Last Post: 21-07-2010, 07:10 PM
  5. 16mm supported rail how many linear bearings
    By progomez in forum Rails, Guideways & Bearings
    Last Post: 15-01-2009, 09:39 PM
