Thread: Laser Machine Grounding/Earthing
If you bought the machine from China I would earth it using the spike. It could be that parts of the machine are electrically isolated from each other. In which case, knowing how they connect the laser tubes, I wouldn't fancy 25 volts bouncing around the frame. :) Basically as he above said. :)
08-02-2015 #2
09-02-2015 #3
you have to consider it in more detail than that !
It depends on your current earth setup.
If my earth is from the elec provider .. and I install a spike .. there could be considerable difference in potential from one earth to the other .. this would cause a large current to flow in the earth wiring.
If I was to add a spike in the workshop, it would be best to use that earth for the whole workshop, and "lift" the incoming earth from the supply
Earthing?
By manofgresley in forum General ElectronicsReplies: 70Last Post: 29-03-2018, 11:56 PM -
Laser Machine Eye protection
By Want2build1 in forum Laser Machines & BuildingReplies: 11Last Post: 19-05-2014, 01:46 PM -
Laser diode module machine addon
By luke11cnc in forum Laser Machines & BuildingReplies: 12Last Post: 06-01-2014, 11:24 PM -
How to save laser machine cost
By Zoe Zhang in forum Manufacturer NewsReplies: 0Last Post: 06-09-2012, 03:41 AM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM
