Thread: Laser Machine Grounding/Earthing
16-05-2014 #5
You can do you own wiring if your considered to be competent but you cant do it for anyone else. Although the exact explanation of competent is a bit vague.
As for your workshop wiring this can require a bit of "expert knowledge" shall we say. Is the workshop part of the house or attached to it or is it seperate from it? Do you know what type of earthing arrangement your house supply has? Most of the time the recommendation is for your workshop to have its own earth, ie make the workshop a TT type arrangement which is the earth rod in the ground.
Earthing?
By manofgresley in forum General ElectronicsReplies: 70Last Post: 29-03-2018, 11:56 PM -
Laser Machine Eye protection
By Want2build1 in forum Laser Machines & BuildingReplies: 11Last Post: 19-05-2014, 01:46 PM -
Laser diode module machine addon
By luke11cnc in forum Laser Machines & BuildingReplies: 12Last Post: 06-01-2014, 11:24 PM -
How to save laser machine cost
By Zoe Zhang in forum Manufacturer NewsReplies: 0Last Post: 06-09-2012, 03:41 AM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM
