Thread: Laser Machine Grounding/Earthing
WG
"Combining both of them wouldnt be a good idea."
That's why I started this thread ! .. I didn't think it would be a good idea !
I think Robin may have suggested to 'un'earth your cooker to make it safer ! lol :P
16-05-2014 #2
Interesting question. Theoretically your generator has 3 phases all off earth. The three phases are divided up between the houses at your substation to try and equalise the load. Your single phase earth connection comes with your mains supply and you back it up by connecting it to a water pipe. The local ground is probably thus already in place, no spike required.
The earth resistance is noted on the house certificate, usually calculated by distance and square mm rather than by measurement. The distance is measured back to the 25mA breaker which is why you see a lot of fat naked copper heading for the fuse box. Overkill makes the sums easy.
16-05-2014 #3
I shall check the cable armour at the house box, when I get a chance :) Thinking about it, it should be earthed !
16-05-2014 #4
typed at the same time !
19-07-2014 #5
To add to this ...
Recently my Laser PSU died.
So, I've had to read up on PSU wiring, inputs and outputs ...
The return wire from the tube is connected to the case/chassis !
so, if you get a bad earth connection in the mains supply or plug - either end- then the chassis is potentially at 25Kv .
Unlikely , you might think but ! ...
I just bought a K40 laser machine as a backup. This arrived with a dud tube. The fault was a cooling water leak INSIDE the tube ! which effectively shorted the 25Kv HT to the chassis !
Sooo .. I think the warning for the extra earth connection direct from machine to ground, is sort of a make do safety precaution, to cover this bad design 'feature' .
When I realised this, I had to wonder how the RCD didn't trip, with a constant 20mA or so leaking to earth. I came to the conclution that the flyback transformer produces an isolated current, so the RCD wont protect you.
It's kind of unbelievable that this is a designed situation, not a fault situation.
So .. check your earth connections everyone !
The Following User Says Thank You to Want2build1 For This Useful Post:
19-07-2014 #6
and more to add ..
Watching a blog vid of someone reviewing a laser in the USA, He stated he had to install the ground wire, as his house didn't have ground wiring !
That was one of my 1st thoughts.. although I assumed the contries like the US would have ground wiring in their houses by now ?
03-02-2015 #7
If you bought the machine from China I would earth it using the spike. It could be that parts of the machine are electrically isolated from each other. In which case, knowing how they connect the laser tubes, I wouldn't fancy 25 volts bouncing around the frame. :) Basically as he above said. :)
08-02-2015 #8
09-02-2015 #9
you have to consider it in more detail than that !
It depends on your current earth setup.
If my earth is from the elec provider .. and I install a spike .. there could be considerable difference in potential from one earth to the other .. this would cause a large current to flow in the earth wiring.
If I was to add a spike in the workshop, it would be best to use that earth for the whole workshop, and "lift" the incoming earth from the supply
Earthing?
By manofgresley in forum General ElectronicsReplies: 70Last Post: 29-03-2018, 11:56 PM -
Laser Machine Eye protection
By Want2build1 in forum Laser Machines & BuildingReplies: 11Last Post: 19-05-2014, 01:46 PM -
Laser diode module machine addon
By luke11cnc in forum Laser Machines & BuildingReplies: 12Last Post: 06-01-2014, 11:24 PM -
How to save laser machine cost
By Zoe Zhang in forum Manufacturer NewsReplies: 0Last Post: 06-09-2012, 03:41 AM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM
