16-05-2014 #1
Howdy
I am in the process of implementing EddieCurrent's safety circuit and have come across a stumbling block primarily with the Hitachi X200 interface to the circuit. I am hoping someone has a better than basic (me) knowledge of the VFD and can throw some light on the inputs to it.
In EddieCurrent's circuit he interfaces with his ABB VFD to execute a Run/Stop from the safety relay. This comes via a spindle control board and it looks like he is controlling his VFD with PWM. From what I can find out from the Hitachi manual I can input a run/stop signal to the VFD but nowhere does it explain what type of input that is. A side note: I currently control the VFD via Modbus using that purely for Start/Stop and speed control from Mach3.
Depending on what form of signal the VFD needs to switch run/stop on & off am I going to need a spindle board and have to switch to PWM control over Modbus or can I use a relay/output pin from Mach to do the switching?
Aside from these X200 gotchas I have everything else to implement the safety circuit. Hoping someone will let me know what I actually need as above.
BruceLast edited by ozspeedway; 16-05-2014 at 01:02 PM.
hitachi wj200 vfd and modbus
By iamspuddy in forum Spindles & Drive MotorsReplies: 0Last Post: 27-09-2013, 07:50 PM -
Hitachi M12VC Router available cheap @ $84!
By leaveme in forum General DiscussionReplies: 0Last Post: 26-08-2011, 10:27 AM
