Thread: VFD error
Been there done this and it cost me VFD + Spindle.!! . . . . . . I made the strain relief from start but temp removed spindle to check some spindle mounts I'd made for some one as didn't have a spare spindle handy but didnt put it back straight away as I had more to make then it got forgot until it did excatly what yours did.!! . . . . . Hope you haven't fried the spindle as well.!
21-05-2014 #2
Given that you've disconnected the spindle, reset the VFD and the fault persists, that implies there actually is a connection between one or more of the UVW terminals to earth. The simplest explanation for that would be an IGBT that has failed to make a short circuit. I'd have a look inside as you should be able to identify this with a multimeter. If it uses an IGBT module then that will be quite expensive to replace and probably not worth the risk, but if it's individual IGBTs it's probably worth a shot - the issue is you don't know if any of the associated circuits (e.g. gate drive) have been damaged.
No problem getting a higher rated VFD than you need, within reason.
If you need the extra torque from the 3kW spindle then clearly get it...
You should try rewinding it - shouldn't be difficult.
repeating code error
By motoxy in forum Programmers CornerReplies: 2Last Post: 28-02-2014, 07:51 AM -
VFD problems, please help. error code DL
By humbo3d in forum Spindles & Drive MotorsReplies: 2Last Post: 09-02-2014, 08:10 PM -
huanyang vfd 2.2 error E.CO.A
By edgas10 in forum General ElectronicsReplies: 0Last Post: 01-07-2012, 08:12 PM -
Solidcam error
By Kai in forum SolidworksReplies: 5Last Post: 10-05-2011, 03:41 PM -
Error on a Bosch cc 220 control (Need help)
By Andre in forum General ElectronicsReplies: 2Last Post: 01-10-2010, 07:33 AM
