Thread: Safe Z Speed
23-05-2014 #11
23-05-2014 #12
I was hoping I could set the G0 moves alot faster than the Feed rates
Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
23-05-2014 #13
Oh thanks lee !
24-05-2014 #14
G0 moves are done at the Velocity set in motor tuning. G1 moves are done at the commanded Feed rate ie G1 X36 F600.
If you have X and Y axis set at different velocity in motor tuning then any blended moves like G0 X300 Y50 will be done at the lowest velocity or some derived velocity based on both so both axis arrive at same point together.
If each axis moves separate then any G0 move will be done at the velocity set for that axis.
What is the velocity for each axis in Motor tuning.?Last edited by JAZZCNC; 24-05-2014 at 12:07 AM.
24-05-2014 #15
X = 4000
y = 4200
z = 2000
Just tried the famous aztec calender "cutting air". The fast feed G0 travels at 1000 units per minLast edited by dudz; 24-05-2014 at 09:06 AM.
24-05-2014 #16
Sounds like you have feed rate override (FRO) set to roughly 25%.
24-05-2014 #17Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
24-05-2014 #18
The feedrate while milling is OK
24-05-2014 #19
24-05-2014 #20
I ran the aztec again. The X and Y travels around 1500 units/min while cutting but as soon as the Z retracts to go to the opposite side, it runs at 1000.
Using Big Tex screen. It states 100% for FRO and Rapid FRO is not shown. I will try in the standard 1024 screen in a minute.Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
Need to slow down a signal due to Safe Torque Off alarm
By corkcnc in forum General ElectronicsReplies: 0Last Post: 04-06-2014, 11:35 PM -
HSM Advisor - High Speed Machining feed & speed calculator
By magicniner in forum CAD & CAM SoftwareReplies: 2Last Post: 20-01-2014, 12:57 PM -
Z safe in g code question
By Fivetide in forum CAD & CAM SoftwareReplies: 7Last Post: 20-02-2013, 08:00 PM -
Speed control
By Saracen in forum Spindles & Drive MotorsReplies: 2Last Post: 29-12-2012, 02:18 PM -
Safe Z Arghhhhhhhh!! Whats going on!
By AdCNC in forum Machine DiscussionReplies: 9Last Post: 18-08-2009, 05:15 PM
