Thread: Safe Z Speed
Sounds like you're using an older version of Mach3, as it's labeled "Rapid Override Rate" here. If there's a button next to it, then click the button to disable rapid overrides and your rapids will move at the motor tuning velocity. Most users don't use that setting. It's only purpose it to set the rapid feedrate at something other than the motor tuning velocity.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
24-05-2014 #2Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
Need to slow down a signal due to Safe Torque Off alarm
By corkcnc in forum General ElectronicsReplies: 0Last Post: 04-06-2014, 11:35 PM -
HSM Advisor - High Speed Machining feed & speed calculator
By magicniner in forum CAD & CAM SoftwareReplies: 2Last Post: 20-01-2014, 12:57 PM -
Z safe in g code question
By Fivetide in forum CAD & CAM SoftwareReplies: 7Last Post: 20-02-2013, 08:00 PM -
Speed control
By Saracen in forum Spindles & Drive MotorsReplies: 2Last Post: 29-12-2012, 02:18 PM -
Safe Z Arghhhhhhhh!! Whats going on!
By AdCNC in forum Machine DiscussionReplies: 9Last Post: 18-08-2009, 05:15 PM
