Thread: Safe Z Speed
Page 3 of 3 FirstFirst 123
  1. #21
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 09-02-2025 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    With 1024 screen loaded. Both Rapid FRO and FRO are at 100%
    No difference
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
  2. #22
    dudz's Avatar
    Ok.. Done it. In Mach3. Open the settings tab. Top left hand box called Fast feed overide. It has 0.00 in the box. I changed the numbers to 1000 and left the tab without pressing enter. Now the 3 axis travel 5x as fast ( when not cutting material ) This is in the standard Mach3 screen. The Big tex screen is different
  3. #23
    Sounds like you're using an older version of Mach3, as it's labeled "Rapid Override Rate" here. If there's a button next to it, then click the button to disable rapid overrides and your rapids will move at the motor tuning velocity. Most users don't use that setting. It's only purpose it to set the rapid feedrate at something other than the motor tuning velocity.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  4. #24
    dudz's Avatar
    Its the latest version as far as I know. Version R3.043.066
    But yes. The button was activated by default and set at 0.00
  1. Need to slow down a signal due to Safe Torque Off alarm
    By corkcnc in forum General Electronics
    Last Post: 04-06-2014, 11:35 PM
  2. HSM Advisor - High Speed Machining feed & speed calculator
    By magicniner in forum CAD & CAM Software
    Last Post: 20-01-2014, 12:57 PM
  3. Z safe in g code question
    By Fivetide in forum CAD & CAM Software
    Last Post: 20-02-2013, 08:00 PM
  4. Speed control
    By Saracen in forum Spindles & Drive Motors
    Last Post: 29-12-2012, 02:18 PM
  5. Safe Z Arghhhhhhhh!! Whats going on!
    By AdCNC in forum Machine Discussion
    Last Post: 18-08-2009, 05:15 PM
