Thread: Safe Z Speed
    Wow dudz I meant post a txt file not the whole 10 million lines of code. . Lol
    Give me 5 and I'll flick thru it.!
    Nope nothing wrong there all the Z retract and X & Y reposition moves are done at G0 rapid feeds. The feeds in the code are on the low side but I presume you have choose those feeds.?
    Are you having this problem while it's running the G-code and changing position ie say cutting several pockets or when sending machine to Home position when finished.?
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 06-06-2026 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    Feed for 6mm single flute = 600
    Spiral down at 300
    I thought that was about right in Aluminium ?.
    usually both, but def when going between pockets etc...
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
    dudz's Avatar
    I was hoping I could set the G0 moves alot faster than the Feed rates
    G0 moves are done at the Velocity set in motor tuning. G1 moves are done at the commanded Feed rate ie G1 X36 F600.
    If you have X and Y axis set at different velocity in motor tuning then any blended moves like G0 X300 Y50 will be done at the lowest velocity or some derived velocity based on both so both axis arrive at same point together.
    If each axis moves separate then any G0 move will be done at the velocity set for that axis.
    What is the velocity for each axis in Motor tuning.?
  1. Need to slow down a signal due to Safe Torque Off alarm
    By corkcnc in forum General Electronics
    Last Post: 04-06-2014, 11:35 PM
  2. HSM Advisor - High Speed Machining feed & speed calculator
    By magicniner in forum CAD & CAM Software
    Last Post: 20-01-2014, 12:57 PM
  3. Z safe in g code question
    By Fivetide in forum CAD & CAM Software
    Last Post: 20-02-2013, 08:00 PM
  4. Speed control
    By Saracen in forum Spindles & Drive Motors
    Last Post: 29-12-2012, 02:18 PM
  5. Safe Z Arghhhhhhhh!! Whats going on!
    By AdCNC in forum Machine Discussion
    Last Post: 18-08-2009, 05:15 PM
