Thread: Safe Z Speed
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 06-06-2026 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    sorry, not sure how to do that
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
    Hi dudz,
    You would just paste the code into a text file and then attach that file to your post, or you could wrap your code using "code" tags and this presents it a little better in your post, have a look above as i've done that for you.
    .Me
  1. Need to slow down a signal due to Safe Torque Off alarm
    By corkcnc in forum General Electronics
    Last Post: 04-06-2014, 11:35 PM
  2. HSM Advisor - High Speed Machining feed & speed calculator
    By magicniner in forum CAD & CAM Software
    Last Post: 20-01-2014, 12:57 PM
  3. Z safe in g code question
    By Fivetide in forum CAD & CAM Software
    Last Post: 20-02-2013, 08:00 PM
  4. Speed control
    By Saracen in forum Spindles & Drive Motors
    Last Post: 29-12-2012, 02:18 PM
  5. Safe Z Arghhhhhhhh!! Whats going on!
    By AdCNC in forum Machine Discussion
    Last Post: 18-08-2009, 05:15 PM
