If I can make a comment on your posts - is everything ok with this project?
No, I simply cannot fathom how to change the standard cartesian x/y positioning into H-plot gantry co-ordinates
I have discovered that it is possible to drive a H-plot gantry system with MARLIN firmware and a RAMPS 1.4 controller on an ARDUINO MEGA 2564 with a wireless receiver lcd doofer, so I have ordered all of that, BUT and I retreat 'under the bridge' awaiting your barrage due to pressing the b.i.n button before realising that I simply cannot import a graphics based .dxf or a .hpgl into the marlin/slicer pronteface stuff, as it will only take an .STL file format.
bugger I say!!
I simply want a little plasma machine to put into my car and take to the compressor/workshop/plasma machine.
I do however like the idea of sending the g-code file to the controller LCD wireless, then pressing go on the LCD.
OH - yes the idea is to make a little H-plot table in one peice, 4 motors in each corner, nema 17's - 4 drivers - one for each motor, as I have been advised it is not good practise to simply affix two motors to one drive, then two drivers to x on the bob and two to y, closed loop belt so I can pluck and tune the tension on the belt.
ALSO having trouble ordering pulleys, I now know I want HTD 5m 9mm belted pulleys in 20 tooths - worked that one out after buying a fair few......... 360 divided by 200 steps = 1.8, simply times by 20 teeth = 36 again!!!
anyways the problems I am having is vendors list them for example '5mm pilot bore' so I simply assumed they were bored all the way through at 5mm - plus the pics show them to be already grub screwed, of which they are not, they are simply drilled a few mm deep at 5mm - - pilot bore.
so what I want now is four 20 toothen HTD pulleys 5mm pitched 9mm belt, bored for 5mm with grub screws.
also want the above in 6.35mm
Is there anyone who can help me bore them and drill and tap them for me? as I don't have a lathe
also want the above in 25mm but maybe 8mm bore, I don't know yet
t seems they simply do not make a 20 toothen 8m HTD pulley 20mm wide.
Grey scale / height map / relief carving
By totts in forum Computer SoftwareReplies: 19Last Post: 11-08-2014, 10:47 PM -
NEW MEMBER: tiny
By tiny in forum New Member IntroductionsReplies: 3Last Post: 02-05-2013, 10:15 PM -
WANTED: Wanted Linear Scale/Encoder
By gavztheouch in forum Items WantedReplies: 9Last Post: 24-01-2013, 05:32 PM -
Ebay 3040 issue with mach3 - incorrect scale when machining?
By Wayne Kinney in forum Artsoft Mach (3 & 4)Replies: 6Last Post: 04-03-2012, 12:17 PM -
Tiny tool feedrates
By Robin Hewitt in forum General DiscussionReplies: 7Last Post: 08-09-2010, 02:48 PM
