    1. Maximum spindle/vfd running off 13a plug?
    2. Unshielded stepper wiring ok (just about)?
    3. How to ground frame?
    4. Anything in addition to built in filter and shielded motor cable required? While I'm at it, anyone know a good place to go for the cable?
    1. Nothing wrong with running 2.2kw off 13A plug. Think 3Kw washing machine
    2. You do need shielded cable to stepper and vfd I use 1mm CY cable. others might say 1.5mm
    3. Connect the frame to your earth star point if possible.
    4.This is one place for it http://quickbit.co.uk/cable/CY-cable...ble-1mm-4-core
    2. The shield on the cable is also earthed at the star point.
    Where did you connect your earth to on the vfd. ..Clive
  1. Looking for some CAM advice
    By m_c in forum Dolphin
    Last Post: 15-12-2013, 10:17 PM
  2. Lathe / Milling for dummies
    By kingcreaky in forum Milling Machines, Builds & Conversions
    Last Post: 04-12-2012, 01:54 PM
  3. what electrics cnc kit to use for 3x4 cnc plasma
    By whensparksfly in forum Plasma Table Machines
    Last Post: 27-02-2012, 07:33 PM
  4. cnc router electrics
    By cncroutman in forum Gantry/Router Machines & Building
    Last Post: 24-07-2010, 09:52 PM
  5. RFQ: Cnc for dummies
    By MIAPISH in forum Projects, Jobs & Requests
    Last Post: 31-03-2010, 07:33 PM
