Thread: Driver switching OFF
Think you should be starting Mach before you start machine
02-06-2014 #2
Ray Do you have the enable pins connected.? If so then either set the correct pins in mach ports & pins or disconnect from drives to be sure.
Doesn't matter if Mach is started first or not but if not setup correctly then the drives won't respond. The fact it's turning off lights leads me to think you have the enable pins connected and this cutting the drive signals.!
03-06-2014 #3
03-06-2014 #4
Ray the enable pins on the drive do exactly that they Enable or Disable the drive output signals. It's common for these pins to be left unconnected but if you do want to use them then you must set the correct pin in Mach3 outputs and set the correct Active state so it activates the Enable on the drive.
To test this then just disconnect the Enable pin at the drive. If the motor output pins are set correct then the motors will move. The motors won't move unless you have set the correct pins in Motor outputs that correspond with those on your breakout board. We can't tell you which pins to use without knowing the breakout board make and model.
03-06-2014 #5
Just realised you may not know what I mean by enable pin.? On the M542 this will be labeled Ena+ Ena-. Disconnect these pins.
04-06-2014 #6
04-06-2014 #7
switching from steppers to servos - STEP / DIR control
By dsc in forum Stepper & Servo MotorsReplies: 6Last Post: 18-06-2014, 12:41 PM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
FOR SALE: 24v 20 amp ABB switching power supply £90
By gavztheouch in forum Items For SaleReplies: 0Last Post: 07-02-2014, 07:42 PM -
Home switching
By Vard in forum General ElectronicsReplies: 6Last Post: 14-03-2012, 08:32 PM -
Driver box
By John S in forum General ElectronicsReplies: 1Last Post: 21-06-2009, 12:46 PM
