Ray the enable pins on the drive do exactly that they Enable or Disable the drive output signals. It's common for these pins to be left unconnected but if you do want to use them then you must set the correct pin in Mach3 outputs and set the correct Active state so it activates the Enable on the drive.
To test this then just disconnect the Enable pin at the drive. If the motor output pins are set correct then the motors will move. The motors won't move unless you have set the correct pins in Motor outputs that correspond with those on your breakout board. We can't tell you which pins to use without knowing the breakout board make and model.
