07-06-2014 #14
Nah too expensive try these people or go to your local bearing supplier as they are often cheaper and will sell without Vat for cash.
http://www.beltingonline.com/timing-pulleys-bars-272/
Your gantry is looking slightly better but still needs work. Also by the looks of it you haven't given much thought to how the ballscrew end bearings will mount and how the motor will connect.? Has it stands now it can't be done without special machining and using FF/FK bearing blocks.
10mm plate would be better for the bearing plate 6mm is still a bit flimsy.! Can't afford any flex or resonance here.
Need advice for a new machine?
By az786again in forum General DiscussionReplies: 7Last Post: 05-03-2014, 02:04 PM -
NEW MEMBER: Designer with a plan looking for advice
By bigstu67 in forum New Member IntroductionsReplies: 2Last Post: 10-10-2012, 06:04 PM -
Advice about a sentence concerning CNC Machine!!!
By hoezap in forum General DiscussionReplies: 5Last Post: 09-11-2011, 02:25 AM -
cnc machine buyers advice
By wyndham in forum Marketplace DiscussionReplies: 0Last Post: 29-06-2011, 06:52 PM -
Machine Buying advice
By jrob3rts in forum Marketplace DiscussionReplies: 0Last Post: 17-09-2010, 04:59 PM
