Yes but don't be under any illusions that it's easy. To pull this off you will need to be well equiped and have the correct skills to use the tools.
With £1200-1500 budget you will have NO room for error or mistakes buying the wrong components.
Building with steel will cut the costs down but requires it's done correctly to achive accuracy, to be honest at this budget it's about your only option to achive accuracy/strength and still leave enough funds to buy the important stuff that makes for a good machine. These being Profiled linear rails, ballscrews and very important is decent quality electronics.
George runs thru the price of main components but what he doesn't mention is that there's a considerable amount of money that gets eaten up from things folks don't see or account for when planning.? Nut & bolts, Wire, Switches, connectors, cable chain and the list goes on. These can really eat money up fast if not careful.
One thing that often happens with people working on tight Budget is that they cut corners in the wrong places.? Often it's the electronics they turn on because they see this taking a big part of the budget.! This is the worse thing they can do and it's in this area where spending money on the correct components can pay dividends in how the machine performs. Get it wrong and take the cheap skate route and you WILL REGRET.
Next area to get the chop is Linear rails.? They often buy unsupported round rail because it's cheap, which it is, but it's also bendy and CRAP. Other option is to use supported round rail which is better but still not the best and comes with problems of it's own, Like constantly needing adjustment and poor accuracey.
Another area skimped on is the Z axis and material thickness.? The Z axis is THE single most important area of the machine and cutting corners here is BIG mistake as it holds the cutting tool and if this flexs or bends then doesn't matter how well rest of machine is built you'll get poor results.
Best advise is BUY NOTHING YET look around the forum at other builds to judge whats required and if you think you have the skills etc needed. If so then pick or design the kind of machine you require and start a build thread and ask advise. STILL DONT BUY ANYTHING until you have the green light and understand FULLY what and why your buying these componets. Again ASK advise on where to buy as often we will know where they can be bought cheaper.
With a Small Budget you have no room for error and in the blink of an eye with a few wrong clicks you could easily spend all your budget and still be some way off a fully working machine that will still under perform if you haven't done your home work.!!
Good luck and ASK questions before Buying.!!
Need advice for a new machine?
By az786again in forum General DiscussionReplies: 7Last Post: 05-03-2014, 02:04 PM -
NEW MEMBER: Designer with a plan looking for advice
By bigstu67 in forum New Member IntroductionsReplies: 2Last Post: 10-10-2012, 06:04 PM -
Advice about a sentence concerning CNC Machine!!!
By hoezap in forum General DiscussionReplies: 5Last Post: 09-11-2011, 02:25 AM -
cnc machine buyers advice
By wyndham in forum Marketplace DiscussionReplies: 0Last Post: 29-06-2011, 06:52 PM -
Machine Buying advice
By jrob3rts in forum Marketplace DiscussionReplies: 0Last Post: 17-09-2010, 04:59 PM
