    Ok,cool :) Ill get on that then... So essentially once the frame is cut,welded and finished you then locate and bolt the rails onto predefined position on the frame, correct? after doing that you then add the stepper motors to the ballscrews, then add the wiring from the motors to the driver boards? then to the powesupply and computer? Make everything look pretty and add a router... is that the assembly in a big nutshell?
    Quote Originally Posted by FlyHighRC View Post
    Wow slow down rover don't go jumping to far in front already. Your nutshell version is a very very very simplified concept and in reality theres a little more to it than that.
    Like I said before go do some home work and look at other build threads and designs to get an idea of whats required. This may seem like wasted time but it's not and will payoff when you are ready to start. If you skip this step you will end up with a lesser machine and big potential for wasted money.
  1. Need advice for a new machine?
    By az786again in forum General Discussion
    Last Post: 05-03-2014, 02:04 PM
  2. NEW MEMBER: Designer with a plan looking for advice
    By bigstu67 in forum New Member Introductions
    Last Post: 10-10-2012, 06:04 PM
  3. Advice about a sentence concerning CNC Machine!!!
    By hoezap in forum General Discussion
    Last Post: 09-11-2011, 02:25 AM
  4. cnc machine buyers advice
    By wyndham in forum Marketplace Discussion
    Last Post: 29-06-2011, 06:52 PM
  5. Machine Buying advice
    By jrob3rts in forum Marketplace Discussion
    Last Post: 17-09-2010, 04:59 PM
