I contact with Chai i ask him to see the videos and he told me
Dear Vagelis,
Can you adjust it as this linked instruction:
Screw Shaft Straightness
AS you know, the ballscrews have to be checked and adusted Before they are mounting to the machine.
Thank you very much for your consideration and cooperation!
Chai
Has anybody followed the above procedure for ballscrew straightening?
I am not sure for the result.The creative adult, is the child who survived
05-06-2014 #2
Yes it's standard way to straighten any shaft not just ballscrews. . . . BUT . . Trust me on this Vagelis chances are they will be OK when on the machine and setup. If any is bent enough to cause a problem then it's not difficult to straighten them like is shown in the link above and often this can be done in a standard vice with pair of V blocks. It doesn't take much effort to straighten screws just a little patience.!
05-06-2014 #3
Personally I'd have a go at straightening them. Whilst the machine will probably 'work' with bent screws, the life of the system (particularly the ballnut) will clearly be lower. How much lower is hard to say, but why take that chance? It's a similar reason for why you shouldn't exceed the critical speed of the screw - whilst sometimes it can look OK as the nut guides the screw, it's still putting larger than normal radial forces on the nut which the nut isn't designed to tolerate.
I straightened a RM1204 ballscrew a while ago. It wasn't challenging.
Just remember not to use steel V-blocks as you could damage the threads on the screw.Last edited by Jonathan; 05-06-2014 at 10:38 PM.
Centec 2 ballscrews
By jonnydeen in forum Lead Screws, Nuts & SupportsReplies: 29Last Post: 11-07-2023, 09:53 AM -
machining ballscrews
By T0rnado69 in forum Lead Screws, Nuts & SupportsReplies: 11Last Post: 13-04-2014, 11:39 PM -
machined ballscrews
By wilfy in forum Lead Screws, Nuts & SupportsReplies: 15Last Post: 30-07-2012, 05:42 PM -
Two ballscrews on both X and Y axis?
By Jonathan in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 02-02-2012, 01:55 AM -
supports for ballscrews
By leadinglights in forum Lead Screws, Nuts & SupportsReplies: 2Last Post: 27-04-2010, 12:31 PM
