    Once you have successfully cast your parts, do you intend to offer cast parts for sale on the forum? If you do I am sure that you will soon get some customers for gantry ends, motor mounts etc. Good luck. G.
    Quote Originally Posted by GEOFFREY View Post
    I agree, I think specialised cast parts would make for a good kickstarter. I would buy a nice cast gantry end that incorporated machined mounting points for linear bearing blocks and ballscrew mounts
    CNC routing and prototyping services www.cncscotland.co.uk
    ADD ME ON FACEBOOKS
    Good idea about the kickstarter, maybe I should keep all my ideas secret in case anyone nicks them :)
    Sod it, here's some pics.
    Here's the start for the gantry pattern. It's 19mm thick and longer than I need as I'm thinking about doing a kit and the gantry can be cut to size. All needs to be sanded smooth and all the inside corners need to have wax fillets put in.
ID:	12539Click image for larger version.
ID:	12538Click image for larger version.
  1. BUILD LOG: Monster fixed gantry router for aluminium & wood
    By jonboycnc in forum DIY Router Build Logs
    Last Post: 12-01-2014, 11:26 PM
  2. Please review this router gantry idea
    By EddyCurrent in forum Gantry/Router Machines & Building
    Last Post: 09-09-2013, 04:47 PM
  3. RFQ: RQF: Router Gantry plates
    By lateAtNight in forum Projects, Jobs & Requests
    Last Post: 27-12-2012, 04:56 AM
  4. BUILD LOG: Fixed Gantry Router
    By lateAtNight in forum DIY Router Build Logs
    Last Post: 28-05-2009, 11:30 PM
  5. Bellows for a gantry mill/router
    By Smiler in forum Milling Machines, Builds & Conversions
    Last Post: 19-11-2008, 09:25 PM
