    Quote Originally Posted by howser37 View Post
    Just found this also
    thanks for any help
    Ok well this shows it's using Limit C for both probe and limit which is pin13. But like Gerry says because you tried it on another input that works then you have wiring fault. (provided you changed the Probe to same number as limit you tried)
    To be honest I'm not 100% sure that link is the same controller you have because it says uses a second breakout board and i don't see one in your box unless it's hidden.? I see a ribbon cable disappearing away underneath the base plate where's that going.?
  1. Z AXIS, big tex blue screen and auto tool sensor Problems
    By Tomnewry in forum Artsoft Mach (3 & 4)
    Last Post: 01-01-2014, 09:01 PM
  2. Tool Height Setting Probe - Mach3 - solution
    By HiltonSteve in forum Tool & Tooling Technology
    Last Post: 12-11-2013, 06:23 PM
  3. What Spindle / Auto Tool Changer?
    By Chaz in forum Tool & Tooling Technology
    Last Post: 01-08-2013, 10:35 PM
  4. how to make auto tool changer on mach3
    By m.vekariya in forum Artsoft Mach (3 & 4)
    Last Post: 13-03-2013, 08:48 PM
  5. Replies: 4
    Last Post: 07-11-2011, 03:26 AM
