10-06-2014 #6
Best to start at the source and it's Possibly a lose connection on the breakout board anyway. Trace the wire back into the control box and see if you can identify the input it's using on the breakout board.
Then to test the breakout board hasn't fried it's input take a short wire and place between the (+) input and Gnd(-) watching the digitise input in mach to see if toggles on/off.
If it does then you know it's either the wire or puck. If not then you probably have a blown Input on the Breakout board.
Z AXIS, big tex blue screen and auto tool sensor Problems
By Tomnewry in forum Artsoft Mach (3 & 4)Replies: 11Last Post: 01-01-2014, 09:01 PM -
Tool Height Setting Probe - Mach3 - solution
By HiltonSteve in forum Tool & Tooling TechnologyReplies: 18Last Post: 12-11-2013, 06:23 PM -
What Spindle / Auto Tool Changer?
By Chaz in forum Tool & Tooling TechnologyReplies: 11Last Post: 01-08-2013, 10:35 PM -
how to make auto tool changer on mach3
By m.vekariya in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 13-03-2013, 08:48 PM -
Problem with height setting in artcam express.
By don_jarr in forum ArtcamReplies: 4Last Post: 07-11-2011, 03:26 AM
