Thread: Milling Machine Advice
14-06-2014 #21
Near enough. I recommend reading Robin's build log as he dismantled some, so you can easily see how it works ... or can be improved with springs (which I've now copied on 3 machines but with separate nuts).
The Following User Says Thank You to Jonathan For This Useful Post:
14-06-2014 #22
14-06-2014 #23
14-06-2014 #24
14-06-2014 #25
14-06-2014 #26
14-06-2014 #27
10-07-2014 #28
After using the mill (and lathe) to make a one off spacer and a couple of other bits I now wish I'd got a mill with a dovetail Z axis and not the round column!! We've got a BILZ tapping head that requires the headstock to be moved up to use and as soon as you move it you lose position so you have to go back to finding your centres again which is a right royal PITA. I'm going to get a cheap laser pointer and mill a 1mm notch in some white plastic and attach the laser pointer to the mill head pointing back at the wall at the plastic. Hopefully (if the plastic is truely vertical) then I can keep the head square. I've discovered that the rack for the head is only wedged top and bottom on the column and not secured in any way so it can flex as much as it likes.....crap design but I guess you get what you pay for. I can see the machine coming apart and the rack being drilled and tapped so it is fixed to the column to stop some of this flexing. Trouble is we seem to have sold a few "one offs" recently so can't do anything to it yet...
Pics of the spacer, the DRO is brilliant for doing PCD's...makes it easy to drill bolt holes.
29-07-2014 #29
Fitted a DRO to the Z axis just now...
WANTED: cnc milling machine
By bigred5765 in forum Items WantedReplies: 14Last Post: 25-04-2014, 11:08 PM -
Need advice for a new machine?
By az786again in forum General DiscussionReplies: 7Last Post: 05-03-2014, 02:04 PM -
WANTED: X3 CNC milling machine
By Nemo1966 in forum Items WantedReplies: 1Last Post: 09-11-2013, 10:42 PM -
Vacuum bed for a milling machine
By martin54 in forum General DiscussionReplies: 3Last Post: 18-10-2012, 10:27 PM -
First CNC milling machine help
By newtoid1986 in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 05-09-2011, 10:06 PM
