    Hi all.
    My newly built CNC milling machine is now moving in Mach 3. I have encountered a problem i am not sure how to deal with. I have 3 Stepper motors, each with it's own Leadshine M542 controller, i can move all my Axis + and - but the movement is not accurate, if i move say X axis 20mm + using the DRO readout in Mach3, i get say 33mm actual movement on the machine!!
    I understand it may be the Dip switch positions on the M542 Drivers, can anyone advise pleased as of correct positions, or know were i can get relevant paperwork.
    Ray
    Ray there is no Correct position. You set the switches according to the amount of micro stepping you want to use.
    Usually on the top of the drive they will show differant combinations of switch positions for each micro step setting you want.
    if you set to micros stepping to 800 or 1600 you'll be ok. This may be shown on the drive as 4x and 8x.
    I've got a M542 here and 1600 would be switch 5=on 6=on 7=off 8=on
    800 would be 5=on 6=off 7=on 8=on
    This doesn't mean yours will be the same as there are lots of copy's that don't always use same settings so I'd check the drives or the manual you got with them.
    Now this is not the end and why your getting the wrong amount of movement.?
    You need to set the Steps per unit in Mach3 motor tuning. To do this divide the micro step amount by the pitch of your lead or ballscrew.
    Thanks Jazz, i'm just a bit confused again.
    My spec sheet for the Stepper motors say's that they are 1.8 degrees, so my maths say's that for every 360 degree rotation, requires 200 steps of the motor, the motors are wired Bipolar Parallel.where on the drive does it indicate 4x & 8x
    Ray
    Quote Originally Posted by manofgresley View Post
    Ray
    http://www.leadshine.com/UploadFile/Down/M542d.pdf
    look at the bottom right of the pdf
    Quote Originally Posted by deannos View Post
    Many Thanks Deannos, i have this paperwork, it still confuses me -
    My motor spec sheet say's 200 step @1.8 degrees each (360 degrees)
    eg, the datasheet say,s Microstep 2 = 400 steps per rev, does this mean the driver has double the speed of my motor?
    Ray
    Lives in Plymouth, United Kingdom. Last Activity: 4 Weeks Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    Quick bit of explanation that might (or might not!) help. Stepper motors usually are built to do 200 steps per rev. This is based on the internal physical layout of the coils and magnetic poles. A simple driver will only allow the motor to move between these "simple" steps. However, most drivers, like the M542, can do something clever in their electronics so instead of energising just one set of coils, they can provide current to both sets of coils but at different levels. Simple case is supply both sets of coils with same current, and the motor will move to a position halfway between the internal poles, so you get a total of 400 steps/rev. By juggling currents, you get "microstepping", where the electronics can move the motor to multiple steps between the 200 mechanical steps. Typical settings are 800 or 1600 microsteps/rev, but this is set purely by the driver and there is nothing on the motor that you change or need to take account of. However, the driver settings generally talk about "x4" or "x8" because whatever motor you use, the number of standard steps/rev is multiplied by this number. We use 200step/rev motors so often that it's easy to forget that there are, for example. 400step/rev motors around, which would give 1600 or 3200 microsteps/rev with the same driver settings.
  7. The Following User Says Thank You to Neale For This Useful Post:
  8. #7
    Many Thanks. i now understand.
    Ray
  9. #8
    Hi Ray.
    Ok well Neale explination says it all really just went round the houses a bit. .Lol
    Most standard steppers are indeed 200 steps per revolution. Which we can then break down into further Micro steps using the drives micros stepping capabiltys. So drives often come with preset micro stepping options. These are 200 which would be classed as full stepping Ie each pulse would move one full step. Then 400, 800, 1600, 2000, which could also be called 1x 2x 4x 8x 10x etc and beyond often upto 256x.
    Now in reality there's no point going any higher than 10x(2000ms) as the motor can't resolve to much more than that. Also it it requires many more pulses from the parallel port so your putting stress on the computer for no gain.
    If you set the drives to 1600 and then set the steps per to 1600/screw pitch then you won't have any issues with incorrect distance movement.
  10. #9
    Ok, old thread but what to do if we use direct drive via coupling from stepper motor to ballscrew
    Ballscrew pitch 5mm
    200steps (one revolution) = travel 5mm or 0.025mm per step.
    1600 steps/rev will give travel 0.003125 per steps
    Is this going to be ok for cut smoothness - final surface quality etc?
    I personally always use gear not direct drive, however all the MC on my work place use direct drive but with servo motors which should not be compared to steppers.
  11. #10
    Quote Originally Posted by Tom J View Post
    Ballscrew pitch 5mm
    You really shouldn't mistake micro-stepping as resolution as it doesn't always translate that way and very much depends on the stepper motor quality. Most can't resolve each step to that degree and accurately hold it repeatably.
    MS is better thought of as helping with smoothness and yes with 1600MS it gives a nice smooth action, 3200 gives better action but now you risk stressing the motion control device, also torque drops as MS increases so voltage/current comes into play.!! . . As with life, there is always a price to pay for anything worth having.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  1. Help withController dip switch settings and Mach3 motor tuning
    By liamo1991 in forum Motor Drivers & Controllers
    Last Post: 15-11-2013, 02:22 AM
  2. 3 wire stepper motor drivers?
    Last Post: 17-08-2013, 10:01 PM
  3. Pulse rate or dip switch settings
    By Jopo in forum Stepper & Servo Motors
    Last Post: 29-04-2013, 08:08 AM
  4. Setting up stepper motor drivers
    By croy in forum Motor Drivers & Controllers
    Last Post: 30-09-2012, 09:51 PM
  5. eBay Stepper Motor Drivers from China
    By Mad Professor in forum General Electronics
    Last Post: 20-07-2009, 10:54 PM
