    These spindles only pull at Max 8amps the VFD manual is recommending to cover all bases. 1.5m/2 will easily handle 8A or anything you throw at these spindles. I've embedded my spindle in aluminium many many times pulling many amps stalling the spindle and loading it to the max without any issues using 1.5m/2 cable.
    The machine should be earthed and adding another earth could create an earth loop and potential problems, it's happened many times before. The VFD is earthed and the shielding should go to the VFD earth point and that is enough. IME.!!
    Well fancy that, all you time served people out there, you wasted four years of your life, it seems you didn't need to know all that stuff after all.
  2. The Following User Says Thank You to EddyCurrent For This Useful Post:
  3. #2
    Keep your knickers on Eddy wasn't saying your wrong or questioning your knowledge I'm saying 1.5mm is fine with these spindles after fitting many of these spindles without any troubles at all.!!. . Which I can't say about those being earthed at the spindle because I've had a few and seen several instances of people doing this and having ground loop troubles.
    Also 2.5mm doesn't even fit the spindle connector so I doubt they where designed to use 2.5mm.!
  5. #3
    my Chinese spindle and vfd arrived today from Portsmouth.the coolant ports as can be seen had fittings previously fitted . i don't know if this is standard practice ( as in testing) or it's second hand spindle and passed on as new. if any one has a previous experience of this i would like to know before i go and contact the seller.
    the VFD appears to be new and doesn't have any sings of previous use. Then again what do i know!! i had a read of
    http://www.mycncuk.com/threads/5814-...HINESE+SPINDLE to try and get to grips with the set up procedure . i'm curious to know if the settings listed in a post by Shinobiwan ( post 6) are still applicable . they are 2 years old but would save some unnecessary manual reading.
ID:	14738   Click image for larger version.
ID:	14739   Click image for larger version.
ID:	14740   Click image for larger version.
ID:	14741   Click image for larger version.
ID:	14742   Click image for larger version.
  6. #4
    Yes this is normal for them to be taken out after testing. They used to leave them in and they often got snapped off in transit, ive had many come like this. If the body was scratched then I'd be suspicous.
    The settings Ant (shinobiwan) posted are still the same I believe.
  8. #5
    cheers Jazz , I didn't fancy getting into a paper trail with the supplier. the body looks fine , no evidence of a mounting bracket. i had a read of the manual and to be honest it would take another good couple of reads to filter out the stuff when compared to Ants post. i'll still need to go over it once i hook up the bob with spindle control. but at least i have enough info to get me testing the vfd with the spindle. thanks again.
  9. #6
    do i need an internet connection to set up the PLCM-E3 OR MACH 3? my garage is a blind spot for a decent signal.
  10. #7
    Quote Originally Posted by PAULRO View Post
    Not for Mach3 but for the PLCM you may need certain windows system programs like DotNet etc to install plug-in and driver etc, depends how upto date your windows is.?
  11. The Following User Says Thank You to JAZZCNC For This Useful Post:
  12. #8
    Lives in Marple Stockport, United Kingdom. Last Activity: 22 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    I think you just download the plugin to a usb stick then you can do it without a internet connection. You might be able to use some homeplug adaptors like these http://www.diy.com/departments/tp-li...150301200758:s
    Solwise do some good ones and TP link are good. ..Clive
  13. The Following User Says Thank You to Clive S For This Useful Post:
  1. NEW MEMBER: Hello everyone. Total newbie here. Where do I begin?
    By DarkWalkJRB in forum New Member Introductions
    Last Post: 07-02-2012, 08:31 PM
