Thread: Let the fun begin !!! ???
18-06-2014 #1
Hello to all,
i have been reading the various project builds on this site and have decided to take the plunge and build a gantry style router. i have a background in machining/ maintenance/ welding/ m/ building , autocad / inventor etc. i'm hoping to avail of the excellent experiences and know how of the various builders on this site. i will use 80 x 80 x 5 box section for the frame but i'm at a loss for overall dimensions. my cutting area will be 1240 x 1240 ( 1/2 standard sheet ) i will be m/cing wood, polycarbonate and light aluminum from time to time. i will use profile rails , ball screws, nema 23 steppers (3) , provision for a 4th axis and a 2.2 kw spindle. so as stated i would like to know the overall size (out to out) of a machine of a similar nature. i will build it in my garage and want to minimize the space used so if any body has built a similar m/c and could get me up and running with the dims. it would be a great help to get the show on the road. by the way, all my selections so far are based on the excellent advice from the various builders on this site. i will post a sketch as soon as i have dims to get the ball rollin' !!!!
cheers,
paulro
19-06-2014 #2
Not that simple really. Yes I could give you an idea of dimensions but to give accurate dimensions then you'd have to build parts of machine exactly the same as I do. IE: Gantry width , bearing spacing Etc.
Best soultion is to get your Autocad and inventor hat on and get sketching then your accurate dimensions will become clear.
24-06-2014 #3
thanks Jazz, i got side tracked and had to change tack for the last week or so. i'm just getting back at the inventor so i should have some dwgs in a day or so.
25-06-2014 #4
hi Jazz, i'm looking for dimensions for bearing blocks for 20 mm ballscrews, could you point me in the direction? i have been reading that fixed blocks at both ends is the best option, ya? i have a frame sketched and am starting into the y axis gantry design
25-06-2014 #5
01-08-2014 #6
At last i have an opportunity to get some images of the intended build posted for comment. i have read a lot of material on this forum and tried to include as much advice as possible . i haven't purchased any materials yet even though i'm itching to get started , but taking the advice given to other potential builders from Jazz, Jonathan , among others, i will build the frame first and then once i'm sure of key dims. i will take on the mechanical purchases and build. the gantry images are posted as a reference to my intended build but as always i'm open to suggestions.
the frame size should take a half a standard sheet ( 1220 x 1220 ) built from 80 x 80 box section. 5 mm wall for the top rails and 3 mm for the rest. the adjustable bed ( yellow) will be held in place by graduated 50 mm x 6 mm angle ( green) secured to the frames uprights. the stand alone box section ( blue ) is detachable to allow space for a fourth axis , eventually!!
i have a choice of extrusion for the gantry ( length 1610 mm ) either 100 x 50 , 4.18 kg/m, 120 x 40 , 4.35 kg /m or 120 x 40 , 6.8 kg /m .
the linear slides, 20 mm hiwins , ballscrews 16 mm and aluminum plate for gantry , 20 mm . i haven't any motor specs yet so i didn't finish the z axis assembly . I might use 20 mm linear slides on the z axis ( off cuts from the 2m x rails ) or just purchase 15 mm rails. i will use epoxy to create a plane for both x axis and a permanent bridge for this and the x axis motor to belt drive the twin ball screws, OR use separate motors for each x axis ballscrew. all to be decided with the advice from the experienced builders here, hopefully!!!! i'm also looking for some motor dims, nema 23 , 3nm. they seem to be the weapons of choice for what i'm about to take on , so if any one can point me in a direction for a reputable supplier that has dims i can use to finish the z axis dwgs i would appreciate it. cheers Paulro.
02-08-2014 #7
Maybe you could incorporate into the fourth axis space something to allow this; http://www.mycncuk.com/threads/7688-...9686#post59686
The Following User Says Thank You to EddyCurrent For This Useful Post:
02-08-2014 #8
ya , that is a great idea. that's what's great about this site , ideas get bounced around and seeds are sown. i've been on this site for the last year getting as much info. as possible and getting cash together at the same time for a router build. can't wait to get stuck in. i'm confident of the mechanical side of the build and have some electrical experience but will need help to get me through the potential pitfalls i think i will find myself in. hopefully i can rely on the experience of the previous builders on this forum.
04-08-2014 #9
The gantry ends look quite substantial but I'm not sure how well the structure will resist twist at the centre, here's some info relating to that subject.
Machine stiffness; http://www.mycncuk.com/threads/7155-...4942#post54942
Stiffness calculator; http://www.mycncuk.com/threads/2214-...5791#post15791Spelling mistakes are not intentional, I only seem to see them some time after I've posted
05-08-2014 #10
Hi Paulro,
Got your PM.
Yes the gantry will be fine for your use as a wood router and yes I've built one about same size using same design so know it works. What you doing with the ends of gantry and how you connecting to ballscrews.? Drawing with gantry mated to frame would be good to see.
Regards Y axis ballscrew mount then you'll need to brace the drop bracket more.
NEW MEMBER: Hello everyone. Total newbie here. Where do I begin?
By DarkWalkJRB in forum New Member IntroductionsReplies: 2Last Post: 07-02-2012, 08:31 PM
